Author Topic: Need help with customizing report templates  (Read 3164 times)
Rade
« on: June 12, 2014, 07:22:28 pm »
I am trying to create a custom template based on Model Report and I'm stuck at the beginning.
I want to remove author name, version, etc that is now displayed for every element (many hundreds  :( ) .
Managed to remove it from diagrams but it still shows for every actor, use case...
Any help, please?
Re: Need help with customizing report templates
« Reply #1 on: June 13, 2014, 09:31:55 am »
Model report heavily uses fragments. You'll have to create copies of each fragment that you want to change. From memory if you give them the same name as the system template they can override the original without needing to modify the calling template.
