Author Topic: typedef struct  (Read 10952 times)
Alec555
typedef struct
« on: June 14, 2014, 12:11:39 am »
I'm pretty new to EA and I've a simple problem with code generation (C). I want to use typedef statement to define a new name. For example I want to get following code:
typedef struct config_tag config;
struct config_tag
      int abc;
So I've created a new UML-diagram, which contains typedef class "config" and struct class "config_tag". Both classes are connected by generalization. After the code generation I'm missing the stereotype struct after the keyword typedef. I'm getting following result:
typedef config_tag config;
struct config_tag
      int abc;
My question is how can I enable to print struct-keyword after the typedef-keyword during the code generation?
I would be appreciated for your help!
greetings
Alec
Makulik
Re: typedef struct
« Reply #1 on: June 14, 2014, 01:25:12 am »
Check the following document
http://www.sparxsystems.com/downloads/resources/booklets/uml_code_engineering.pdf
There are several options, stereotypes and tags, that control code generation for C and C++ in detail.
Best regards,
Günther
