Author Topic: ElementClass for ItemConveyed/InformationFlow  (Read 4396 times)
CThompson
« on: June 17, 2014, 09:21:12 am »
I am new to EA and SysML so this question might seem amateur.
I have a report template that extracts the elements in a package as well as the connectors between those elements. In addition to the connectors I want to extract the information flow on each connector. I was able to do this with EA's guidelines; however, I was not able to extract the tagged values of the information flow. I am now creating a SQL query to pull the tagged values of the information flow but I can't find how information flows are classed to complete the query. Can anyone help please?
Re: ElementClass for ItemConveyed/InformationFlow
« Reply #1 on: June 17, 2014, 07:07:46 pm »
There are a couple of useful threads about retrieving the information flow. Try the search button top left.
CThompson
« Reply #2 on: June 18, 2014, 12:13:47 am »
I searched the Forum before posting and I found only 3 threads related to information flows none of which answered my question. I will try searching other terms to see if anything pops up. Thank you.
« Reply #3 on: June 18, 2014, 01:00:16 am »
I searched for "information flow" (with a space in between) and  (all posts). That returned a lot of results.
CThompson
« Reply #4 on: June 18, 2014, 02:24:13 am »
Thank you  :). Found it!
CThompson
« Reply #5 on: June 18, 2014, 04:22:55 am »
Hi again,
I came up with this SQL Query and I was wondering if you could review it for me. This is my first SQL and I don't have any resourec on SQL besides what comes up on the search engine( Google,Bing) and on this Forum.
SQL Query:
SELECT t_taggedvalue.name As Name , t_taggedvalue.value As Value
FROM t_package, t_xref xCon, t_xref xFlow t_connector c, t_connector flow, t_objectproperties
GROUP BY t_taggedvalue.name
Does this query look like it is capable of extracting the tagged values of an information flow?
« Reply #6 on: June 18, 2014, 04:32:46 am »
Well, on a first sight: t_taggedvalue is not what you might think. Try t_objectproperties (and have a look in my Inside book).
And most obvious you need to connect t_objectproperties and t_object via the object_id.
« Last Edit: June 18, 2014, 04:34:19 am by qwerty »
