Author Topic: Diagram Resolution Setting  (Read 9437 times)
Athanasios Anastasiou
« on: June 13, 2014, 10:56:16 pm »
Hello everyone
I am trying to embed some EA generated diagrams to a latex document but i can't seem to be able to tune the spatial resolution of the diagrams.
If i use a diagram as exported it occupies a whole page. If i rescale it, it becomes blurry.
The typical 'trick' i apply with other software is to bump up the spatial resolution to 300 DPI and then scale the document to the exact dimensions i need. This leads to a smooth and comprehensible print-out with a lot of detail.
But with EA, i am currently stuck at 72 DPI.
Could you please let me know how i could change the resolution at which the diagrams are rendered by EA?
Looking forward to hearing from you
AA
Re: Diagram Resolution Setting
« Reply #1 on: June 14, 2014, 12:21:01 am »
You could export it as wmf and fiddle that externally.
N.B. I found that the resolution for my LaTeX files was fairly ok with defaults. Of course not, if you scale up a single element to page size.
« Reply #2 on: June 16, 2014, 09:15:53 am »
There is an option to scale up the size of generated images. (Tools | Options | Diagram | Scale Saved bitmaps to...
« Reply #3 on: June 19, 2014, 10:28:01 pm »
Hello qwerty & Simon M
Thank you very much for your responses, both useful in different cases. I will go with the 'scale the diagram up' for the moment, at least for print material.
All the best
AA
