Author Topic: Apply Filter automatically when opening diagram  (Read 2304 times)
EAUser
« on: June 23, 2014, 06:14:00 pm »
Dear EA-community,
In a first EA-Project, I am modelling several use cases linked to high-level use cases. Depending on which high-level use cases are looked at, other use cases are more or less important.
I would like to model these use cases in the same diagram with other use cases highlighted depending on the high-level use cases looked at. I am currently realizing that by adding keywords to the use cases and installing diagram filters to highlight the use cases which contain a certain keyword property.
So far, this works pretty well. But when I include this diagram as composite diagram in the high-level use cases, it would be great if a diagram filter would be applied automatically depending upon the high-level use case we came from.
Is that possible? Or is there any smarter way to realize this construct?
Thank you for your help!
