Author Topic: SPEM Process Portal  (Read 3892 times)
Henrique Narciso
SPEM Process Portal
« on: July 21, 2009, 12:20:58 am »
Hello, after modeling the process I would like to generate a Process Portal.
From the HTLM REporting I can generate it, however it is full of undesirable links, atributes, dates etc...
Is there a way to generate a clean" HTML page, with only the images, hiperlinks embeded in the artifacts and the detaisl/notes of these artifacts?
If this can only be made by tayloring the html template in the resources... has some else done this already?
thanks in advance.
Henrique Narciso
Re: SPEM Process Portal
« Reply #1 on: July 21, 2009, 01:43:59 am »
thanks in advance.
Refering to this topic again...
How do I keep the imported images in the model in the HTML report?
« Reply #2 on: July 21, 2009, 08:03:08 am »
Did you try out the new TOGAF 9 beta? It seems to have SPEM 2.0 support. Perhaps Sparx also added or updated other features.
Henrique Narciso
« Reply #3 on: July 21, 2009, 08:48:38 pm »
just tried the TOGAF and it works like a charm!
The down part is that i have to buy it rigth? at least the image feature should be in the standard product.
Thanks!
« Reply #4 on: July 22, 2009, 08:43:15 pm »
My guess (I am just a user, not the authority on this) is that if you have one (you need to check which) of the "Engineering" editions or the Ultimate edition of EA then you only need to download the TOGAF module. The license is included in the EA edition.
You need to verify that with Sparx though.
« Last Edit: July 22, 2009, 08:43:41 pm by Midnight »
