Author Topic: Structured tagged values with enumerations  (Read 6105 times)
Jayson
« on: June 30, 2014, 09:59:03 am »
Hi all
I'm using version 9.3 to create a structured tagged value where the individual attributes within the structure tagged values are taken from enumerations.
I follow the standard method:
1. Create an enumeration called "Project_Health" that contains four elements.
2. Create a class called "Project Health" and add six different attributes (each describing a different facet of project health), each of which has its type set as "Project_Health".
3. Finally, I add an attribute to my stereotype that has "Project_Health" as its type.
When I deploy my MDG something goes awry.
I have a structured tagged value just as I expect, but the enumerations don't work.
Instead, it lets me type text into each of the attributes.
Am I doing something wrong or have I just hit a limitation in Sparx?
Your help would be appreciated.
Cheers
Jays  :)
Re: Structured tagged values with enumerations
« Reply #1 on: June 30, 2014, 03:42:32 pm »
Have you used the ellipsis button to set the type?
AndyJ
  • It's only a model
« Reply #2 on: June 30, 2014, 03:47:47 pm »
I don't know if this helps...
When doing this manually (through the user interface) you set the following:
Tag Name (Stakeholder Type)
Description (Broad classification of stakeholders)
Detail (
Type=Enum;
Values=Board, Assurance Group, Business Rep, User, Other;
Default=User)
Are you setting the equivalent of these things?
Andy
Jayson
« Reply #3 on: July 01, 2014, 04:27:09 am »
Hey there, yup I think I am setting the equivalent of these.
I dragged an enumeration element from the profile toolbox and added a number of attributes.
Incidentally, where in the UI would I enter that equivalent text?
Cheers
Jays  :)
Jayson
« Reply #4 on: July 01, 2014, 04:29:11 am »
You mean within the class that is used to define the structured tag value?
If so, then yes.
« Reply #5 on: July 01, 2014, 05:05:04 am »
Cheers
Jays  :)
Use the Default Tags Editor icon (right of the X) .
P.S. You might send me your profile package for a review if it's not confidential. My mail address can be found in the ad-link below.
« Last Edit: July 01, 2014, 05:07:07 am by qwerty »
AndyJ
  • It's only a model
« Reply #6 on: July 01, 2014, 08:55:24 am »
From the menus:
Settings
UML Types
Tagged Value Types (the second tab)
« Reply #7 on: July 01, 2014, 09:47:34 am »
It's a while since I used structured tagged values, but ISTR the individual fields can only be simple strings.
Jayson
« Reply #8 on: July 01, 2014, 10:57:36 am »
Thanks for that.
At least if I know that it is a limitation with a product (rather than me), I can stop beating my head against the keyboard!  ;)
