Author Topic: Assigning images to custom stereotypes  (Read 14325 times)
AndyJ
  • It's only a model
Re: Assigning images to custom stereotypes
« Reply #15 on: July 16, 2014, 09:33:15 am »
I just put this part of the shape script at the end, and prefix it with a bunch of:
println(" ");
println(" ");
Until it appears below the shape.
There are probably more elegant solutions...
Andy
« Reply #16 on: July 16, 2014, 09:46:50 am »
This one puts the name on the bottom edge of the shape:
shape main
      layouttype="border";
      image("ImageName",0,0,100,100);
      addsubshape("name","S");
      shape name
            h_align="center";
            print("#NAME#");
Jayson
« Reply #17 on: July 16, 2014, 10:05:24 am »
Awesome! Thanks a bunch  :)
So I should be able to make it possible for the user to edit the name directly on the drawing using the editablefield property right?
I added:
editablefield = "name";
 just before
print("#name#");
but nothing seemed to happen.
Is this because the text is outside the 100 x 100 box?
« Reply #18 on: July 16, 2014, 10:49:34 am »
Press F2
Jayson
« Reply #19 on: July 17, 2014, 07:19:39 am »
You mean select the object with the mouse and hit F2?
Tried that and nothing.
Sunshine
  • Its the results that count
« Reply #20 on: July 17, 2014, 02:24:06 pm »
That worked perfectly, thanks for that.
Is there any way to print this on the outside of the image box so that it doesn't sit on top of my nice pretty image?
In addition to the previous suggestion you could try putting the print statement in a shape label to get floating text label.
shape label
    print("#name#")// draw a floating text label
RTM: http://www.sparxsystems.com/enterprise_architect_user_guide/10/extending_uml_models/writing_scripts.html
« Last Edit: July 17, 2014, 02:30:37 pm by phenzell »
Happy to help
