Author Topic: only show certain connector types  (Read 5814 times)
SomersetGraham
« on: July 17, 2014, 07:36:51 pm »
Hi
Is it possible to only show certain connector types on a diagram?
I only want to show realisation relationships on a particular diagram
Any hints gratefully received
Using V12
philchudley
Re: only show certain connector types
« Reply #1 on: July 17, 2014, 07:53:04 pm »
Yes
[highlight]Open your diagram
Select Diagram --> Advanced --> Show Visible Relations from main menu
On the dialog, select the relations you want to show[/highlight]
(they are grouped according to type)
Hope this helps
Cheers
Phil
Models are great!
SomersetGraham
« Reply #2 on: July 17, 2014, 08:50:50 pm »
Thanks!!
Using V12
« Reply #3 on: July 18, 2014, 09:43:18 am »
Or you can use diagram filters. Depending on which version of EA you are using, it's something like
Diagram > Diagram Filters, click New Filter, enter Filter Name, click OK, search on Connector, Include > ConnectorType > Equal To > Realization, click OK, then select the diagram filter you just created.
« Last Edit: July 18, 2014, 09:45:52 am by KP »
Graham_Moir
« Reply #4 on: July 21, 2014, 11:03:31 pm »
But KP, won't that then mean the filter is applied to EVERY diagram in the model  ?  Unlikely to be a good solution if that's the case.
RoyC
  • Read The Help!
« Reply #5 on: July 22, 2014, 08:26:47 am »
Yes and no - if the filter is left enabled, it will apply to any other currently open diagrams and any diagrams you subsequently open. If you enable the filter on a diagram and then disable it, you effectively use it only on the diagram you are reviewing.
However, you can't enable a filter so that another user then opens a specific diagram and sees the effect.  The Help is not very clear on that point, so I have edited it to state that, whilst a filter is available to any model user, USE OF the filter is specific to the user and you can't turn on a filter under your user ID for the benefit of another, independent, user.
« Last Edit: July 22, 2014, 08:46:08 am by RoyC »
Best Regards, Roy
Graham_Moir
« Reply #6 on: July 22, 2014, 06:59:23 pm »
That is good information Roy, thank you.  However I have to say that after what I just learnt, diagram filters now leave even more to be desired, at least in my case.
I would definitely like to apply a filter and have a diagram with the filter applied visible to other users.  I'd also really like to:
- create a diagram and populate it,
- then clone it multiple times and highlight different specific parts of it on each clone using different filters
- have the HTML output reflect the set of diagrams and applied filters
In my view, this would be a very useful communication and education mechanism.  In fact I think I'll add this in the suggestions and requests section.
« Last Edit: July 22, 2014, 07:07:52 pm by Graham_Moir »
