Author Topic: Attributes of a Scenario  (Read 3604 times)
Ian Mitchell
« on: July 23, 2014, 02:30:27 am »
I'd like to add some attributes to Use Case Scenarios, mainly 'Story Points' to help with estimating and managing my project.
Does anyone know a work-around for this, because sadly, there's no way to attach anything to a Scenario - tagged value, or connector, 'cos it's not a proper element. But is there any way to make it look a bit more like one?
Current - rather poor - work-around is to run a little script to create new <<scenario>>Use Case elements from the proper use case, and attach attributes to this, but it's clunky, and I have to re-run it each time I create a new Scenario.
www.eaDocX.com
www.theartfulmodeller.com
jfzouain
Re: Attributes of a Scenario
« Reply #1 on: July 23, 2014, 03:56:10 am »
Hi Ian
Don't know if I am understanding you correctly, but you can add a Tagged Value to UC , call it UC Estimate and add a value, or if you need to do this in a step of a structured scenarion you have 3 columns that you can use to add any value here: Uses, Result and State.
Best regards
Jose Zouain
