Author Topic: Alternative Image  (Read 3566 times)
Pieter Erasmus
Alternative Image
« on: July 24, 2014, 09:57:28 pm »
I want to replace an object's image with an alternative image that I created using an EMV/WMF file (I used Visio to create the MWF file). How can I ensure that the object's name appears within the image and not below the image when I replace an object's image with the new alternative one?
Graham_Moir
Re: Alternative Image
« Reply #1 on: July 24, 2014, 10:31:08 pm »
Not sure you can do that.  You can hide the name using the "Hide name under image" option, and then you might need to add a text element, bring it to the top in the z order and place it over the image.
« Reply #2 on: July 28, 2014, 09:54:56 am »
If you apply the image using a shape script, you can write the name over the top, like this:
shape main
      v_align="center";
      h_align="center";
      image("ImageName",0,0,100,100);
      printwrapped("#NAME#");
« Last Edit: July 28, 2014, 09:55:24 am by KP »
