Author Topic: EA from the Command Line  (Read 5835 times)
philchudley
« on: July 22, 2009, 12:29:32 am »
Hi All
Does anyone know if it is possible to give the filepath of the floating license store as a parameter to ea.exe in much the same way as you can give the filepath of a ea project file?
for example
ea.exe %1 %2
Where %1 is the filepath of the project (or connection string)
and %2 is the filepath of the floating license store
Cheers and thanks
Models are great!
Re: EA from the Command Line
« Reply #1 on: July 22, 2009, 09:07:24 am »
No, it's not possible.
lubos
« Reply #2 on: July 24, 2009, 06:23:24 pm »
You can overcome it by manipulating the registry. we use the following command:
reg add "HKCU\Software\Sparx Systems\EA400\EA\OPTIONS" /v AutoCheckoutSharedKeyArray /t REG_BINARY /d 02 /f
reg add "HKCU\Software\Sparx Systems\EA400\EA\OPTIONS" /v SharedKeyFolder /t REG_SZ /d "C:\PATH\_licence" /f
philchudley
« Reply #3 on: July 25, 2009, 01:57:50 am »
Thanks am I correct in assuming that the path after /d in the last reg entry is the file path to the shared licence store?
Models are great!
lubos
« Reply #4 on: August 06, 2009, 07:38:00 pm »
Yes, you are right
