Author Topic: Link Unit tests with Requirements  (Read 3486 times)
Elvys
« on: August 12, 2014, 10:56:58 pm »
Hallo together,
Maybe a similar post already exists but I don't find the right words to receive good result using google.  :-[
I'm documenting the steps of development using EA10.
The first step was to collect the requirements with the Model View "Core Extensions --> Requirement".
A second step was to create a Component Model.
Then some Unit tests for a few components were created. (Like described in  http://www.sparxsystems.com/downloads/whitepapers/test_management_enterprise_architect.pdf on page 4.)
Now I wanted to show which test "verify" which requirement by I don't find out how to do this.
When I insert a Test Case directly in the diagram of the requirements I can do this without any problem, but then the test is separated from the component, isn't?
I thank you in advance for any suggestion.
Kind regards
Elvys
