Author Topic: How to add an "implements" to code gener  (Read 3242 times)
Sergey Woofer
« on: August 13, 2014, 04:00:38 am »
How to add "implements" to code generation (Java for example) without adding an interface?
Java already have a lot of built-in interfaces, I don't need them all in the class diagramm. Just want to have an implements of special class in code generation.
Thanks in advance for help.
« Last Edit: August 13, 2014, 04:01:18 am by subw0fer »
Re: How to add an "implements" to code gener
« Reply #1 on: August 13, 2014, 09:04:32 am »
The element menu contains Set parents and Interfaces (or use the keyboard shortcut Ctrl+I)
Sergey Woofer
« Reply #2 on: August 14, 2014, 04:17:49 am »
Thanks, but this is not that I would like to do. This method don't ask which interface I want to implement.
OK, for example I want to generate code like this:
class CallableThread implements Callable<Integer>{
What should I do?
« Last Edit: August 14, 2014, 04:18:19 am by subw0fer »
« Reply #3 on: August 14, 2014, 09:06:31 am »
Select your class
Ctrl+I
Type Callable<Integer> into the class name field.
Select type of Implements
Ensure Accept classifier even if not in model is checked
Click Add
Click Close
Generate code.
Sergey Woofer
« Reply #4 on: August 15, 2014, 02:15:22 am »
Many thanks! It working like miracle! :)
