Author Topic: Working with Block Diagram Links  (Read 5257 times)
rayj
« on: August 25, 2014, 10:02:56 pm »
How can I learn how to efficiently build links between blocks?
When I make a link and I want subsequent links to be similar, the 'Get Style' and 'Apply Style' don't seem to work.  So I click each link and use the context menu to select the style.  Is there a more efficient way to do this?
Ray
Re: Working with Block Diagram Links
« Reply #1 on: August 25, 2014, 11:11:30 pm »
There are not many options. Connectors are 2nd class citizens. You can set a few defaults via Tools/Options/Links but style only applies to elements. If you want more sophisticated settings you might consider writing an add-in.
rayj
« Reply #2 on: August 26, 2014, 02:10:59 am »
q
Thank you.  I'll just give more attention to that second class citizen.
I read somewhere else about people writing add-ons.  Where can I read more about that?  I found a page of what add-ons have been built.  Is there info and how to build add-ons?
Ray
« Reply #3 on: August 26, 2014, 02:23:35 am »
Check out Geerts page. He has some framework and a special EA Explorer and a tutorial on how to write an add-in in C++.
If you want to get acquainted with EA's API of course I can recommend my books ;)
rayj
« Reply #4 on: August 26, 2014, 11:15:58 am »
q
Thank you for the info.  When I first read about EA, I began wondering about the relationship between designing systems via SysML and designing the design processes with BPM.  I see that you have a range that seems to span these domains.
What's your thoughts?
Ray
« Reply #5 on: August 26, 2014, 05:00:17 pm »
I's actually C#, but thanks for the reference :)
« Reply #6 on: August 26, 2014, 06:41:59 pm »
I's actually C#
From my perspective not a real difference ;D
