Author Topic: Adding a Tagged Value Note to a stereotype  (Read 4056 times)
jplusip
« on: September 03, 2014, 03:53:27 am »
What I mean is this:
Consider the requirement (SysML 1.3:: Requirement), EA has its text in as a Tagged Value Note as seen below:
What type of attribute would I use in my stereotypes' metamodel to give them the same attribute?
Right now I have the text based attributes set as strings, but these are excessively limited in available size and they don't appear in the text box at the bottom of the top up (unlike the requirement's text).
Bonus Question: How do I set what pops up when I put the mouse over my stereotypes? My assumption is that the answer to this is "scripting".
Re: Adding a Tagged Value Note to a stereotype
« Reply #1 on: September 03, 2014, 05:45:06 am »
I'm not quite sure what you're after. But if you want the memo to pop up just put the text "<memo>" (without quotes) in the TV string.
jplusip
« Reply #2 on: September 03, 2014, 07:37:06 am »
That did what I wanted it to do. Thanks!
