Author Topic: Documentation Fragment Template - separated list  (Read 6401 times)
Zdenek
« on: September 04, 2014, 02:04:02 am »
I would like to create Fragment Template which inserts comma separated list of names of child elements filtered by stereotype.
I created Fragment Template based on following SQL query:
SELECT Name
FROM t_object
WHERE Stereotype = 'somestereotype' and ParentID = #OBJECTID#
and content is
[highlight]custom>[/highlight]
{Name}[highlight]<custom[/highlight]
it's working but...
I would like to get output in following form (problematic pieces of text is [highlight]highlighted[/highlight]):
[highlight]Label: [/highlight]Name1[highlight], [/highlight]Name2[highlight], [/highlight]Name3[highlight], [/highlight]...
And I don't know how to say in template engine language that "Label: " should be placed before first item (and if there is no items, there must be there no label) and ", " between two items.
Does anybody know how to change content of my Fragment Template to achieve required output?
Zdenek
danbosscher
Re: Documentation Fragment Template - separated li
« Reply #1 on: September 04, 2014, 05:56:42 am »
Try
Label: [highlight]custom>[/highlight]{Name}, [highlight]<custom[/highlight]
Anything within a section (such as custom) should be repeated for each item. If it is the name of a recognized field enclosed in brackets {}, it will be replaced the current value for that field, otherwise it is treated as a literal.
I don't know what happens if there are no items, but placing Label before the beginning of the section will keep it from being generated more than once.
« Reply #2 on: September 04, 2014, 09:03:32 am »
You can do it by inserting bookmarks. (In my example below a bookmark called LIKETHIS would be shown as {LIKETHIS})
[highlight]custom>[/highlight]{CustomSQL_TITLE_Begin}Label: {CustomSQL_TITLE_End}{CustomSQL_LIST_Begin}, {CustomSQL_LIST_End}{Name}[highlight]<custom[/highlight]
Zdenek
« Reply #3 on: September 04, 2014, 05:50:29 pm »
I am sorry, but I was not able to find how to correctly insert bookmarks into my template.
I found in context menu option Insert/Bookmark... with following items: CustomSQL_Begin, CustomSQL_Begin_Inner, CustomSQL_End, CustomSQL_End_Inner
But didn't found way how to insert it into text.
When I select one of bookmarks and click Insert button, dialog is closed but nothing else happens. I of course tried all other buttons and double click.
I tried to copy & paste bookmark name and put it into {} but then it was just placed to output document.
I am using EA version 11.1.1110
Thanks for your help :-)
Zdenek
« Reply #4 on: September 04, 2014, 08:36:18 pm »
Ok, after deeper investigation and RTF source analyzing I understand how it works.
So, my problem is solved  :) although working with RTF bookmarks is not user friendly (or I am missing some option how to make them visible in EA editor).
Thanks for help
« Reply #5 on: September 05, 2014, 08:54:05 am »
You're right. It's not at all user friendly. Unfortunately there's a lot to be desired about the use of bookmarks, and so far I have been unable to push for improvements.
AndyJ
  • It's only a model
« Reply #6 on: September 05, 2014, 01:25:19 pm »
I made quite a bit of headway with the RTF editor, and then tried Ian Mitchell's tool.
I wonder if I can invoke him by uttering the magic word:
[size=16]eaDocX[/size]
