Author Topic: Mass change of Activities to Actions  (Read 13262 times)
gregf
  • I love YaBB 1 Gold!
« on: December 14, 2005, 01:27:06 pm »
I've created several activity diagrams using only Activity nodes. I'd like to redo these diagrams with activities as actions, so I can leverage Activties, Subactivities, and Actions.
Is there a way to do this?
Greg
mikewhit
  • Accessing ....
Re: Mass change of Activities to Actions
« Reply #1 on: December 15, 2005, 12:45:09 am »
leverage is a noun ... please ?!
Graham_Moir
« Reply #2 on: December 15, 2005, 01:10:00 am »
Yes, "leverage" is a noun, heavily used in Financial Services.
I too would be interested in doing this, but it seems the "Change type" option on the element advanced menu is only available when you have a single element selected.    May be this is an enhancement request.
Following more general thread probably also applies
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=suggestions;action=display;num=1131225620
« Last Edit: December 15, 2005, 01:53:35 am by Graham_Moir »
gregf
« Reply #3 on: December 15, 2005, 12:54:48 pm »
Main Entry: leverage
Function: transitive verb
Inflected Form(s): -aged; -agĀ·ing
: to provide (as a corporation) or supplement (as money) with leverage; also : to enhance as if by supplying with financial leverage
Ok, my usage is poor, but it is a verb...
« Reply #4 on: December 15, 2005, 01:42:09 pm »
Mike 's not that bad. But probably he has a 2nd job as English teacher  ;D
Graham_Moir
« Reply #5 on: December 16, 2005, 04:14:09 am »
It's both a verb and noun.  As a noun in Financial Services it is equivalent to "gearing".
mikewhit
  • Accessing ....
« Reply #6 on: December 16, 2005, 05:21:44 am »
No, I just hate its usage as a verb.
It presumably comes from 'leveraged buyout' where the value of shares in the purchased company is used to increase the value of the bid - or something like that.
The share values gives additional 'leverage' to themselves. That's fine.
But I increasingly notice it lazily used as a verb to just to mean "apply" or "use", without any concept of obtaining additional 'leverage' (improving a performance ratio by its own effort), and hence dislike it being used this way, since it properly refers to the property possessed by a lever.
Also on my hit list: "prepend" - what's wrong with the real word "prefix" ?
Have a good weekend, modellers !
« Last Edit: December 16, 2005, 06:58:30 am by mikewhit »
gregf
SUCCESS!!! - Mass change of Activities to Actions
« Reply #7 on: December 16, 2005, 09:19:55 am »
I leveraged my database skills to find a solution to this problem.
1. Rename yourprojectname.EAP to yourprojectname.MDB
2. Open access database file with MS access
3. Open the t_object table
4. Update t_object set object_type = 'Action' where object_type = 'Activity'
While I DO NOT guarantee it's safety, this hack worked perfectly for me with no side effects, changing everything from an activity to an action. I presume you could hack this table to mass-change any object type.
I'm such a 733t h4xOrZ.
Yours in leverage,
-Greg
Bruno.Cossi
Re: SUCCESS!!! - Mass change of Activities to Acti
« Reply #8 on: December 16, 2005, 10:08:54 am »
just a note: you do not even need to rename the .EAP file to .MDB, .EAP files open in MS Access perfectly fine.
What, pray tell, is "733t h4xOrZ"? :-)
Bruno
Yours in leverage,
-Greg
« Reply #9 on: December 18, 2005, 01:08:57 pm »
I've never been able to read or write Leet, but I think a rough translation would be 'elite hacker'.  Mind you do correct me if I'm wrong.
mikewhit
  • Accessing ....
« Reply #10 on: December 19, 2005, 04:39:07 am »
No, a h4x0r is a small fine-bladed tool for cutting metal, wood or plastic items.
733t just means it isn't heavy.
« Reply #11 on: December 21, 2005, 02:50:35 am »
Google shows this  ;D and many more results. What a small world!
mikewhit
  • Accessing ....
« Reply #12 on: December 21, 2005, 04:53:21 am »
The item referenced by Thomas refers to people who are "lame".
No doubt this result from overuse of the "pedofile" tool referenced in the item, which must presumably be a rough-surfaced implement for abrading parts of the foot.
« Reply #13 on: September 15, 2014, 02:07:57 pm »
I just encountered this, wanting to change a number of artifacts to classes.
On my diagram I can select multiple artefacts (yay).
The Element > Advanced > Change Type   lets me select "Class" and then OK,
but .... (hush of anticipation)
only one of the selected objects actually changes
(sighs of disappointment)
not in EA 11
« Reply #14 on: September 15, 2014, 03:22:58 pm »
I better not update my time to fix statistics since this would add 9 years for a (still not) fixed bug.
