Author Topic: Type - Prototype (Type-Property) classes  (Read 3020 times)
Anders Sandberg
« on: September 26, 2014, 09:52:39 pm »
Hello
I have an issue for which there has to be a simple solution.
I am trying to build the structure of a problem before actually knowing  all the details and I want to show the elements needed in the solution to more simply come up with the necessary interfaces.
To do this I create a class(type) for each element assign it with a Stereotype in the project browser.
In a Structure diagram I will drag the Classes into the diagram and select to use it as a Property(prototype).
This leads to a diagram with a number of Properties linked to the Type of the Class it was created from.
When I change the Class(type), I cannot find a way to update the Property with the new ports.
This seems like a reasonable way to work but I cannot find any informaiton on how this update is made.
Am I doing something wrong or is this not supported in EA?
best regards
Re: Type - Prototype (Type-Property) classes
« Reply #1 on: September 26, 2014, 10:35:31 pm »
Have you read about MDA (Google is your friend)? You can apply that in EA using different views and (if you like) a transformation script.
