Author Topic: Non-displayable tags; where do I go wrong?  (Read 4426 times)
Martinigue
  • BlackBerry is a lifestyle
« on: September 26, 2014, 10:44:39 pm »
Hi Sparxers,
I have loaded the Strategic Modeling package and added an instance of the Decision Tree diagram; added some Test and Outcome Activity elements to it and decorated those with a couple of tagged values. Now, even with the Show Compartments::Tags for elements on a diagram and Tags checked in the Feature visibility dialog for each element, I still cannot see the tagged values displayed. This drives me nuts ..what am I missing?
Mac
Re: Non-displayable tags; where do I go wrong?
« Reply #1 on: September 26, 2014, 11:50:37 pm »
Maybe that when you create an instance the TVs are not copied from the class? Does the TV pane show tags?
Martinigue
« Reply #2 on: September 27, 2014, 12:05:59 am »
All the tags and their values are visible in the Tagged Values pane, that makes it even more arcane for me ...
« Reply #3 on: September 27, 2014, 01:20:03 am »
Another thought is that the model elements have a shape script which supersedes the normal rendering. Maybe you remove the stereotype from a single instance to verify that.
Martinigue
« Reply #4 on: September 29, 2014, 05:14:58 pm »
To clarify: what you suggest is dropping the stereotype for one instance and checking if the Tags compartment shows up?
« Reply #5 on: September 29, 2014, 09:28:58 pm »
Yes. Just for test purpose.
Martinigue
« Reply #6 on: September 29, 2014, 11:24:33 pm »
Ok; no change for me and I will not pursue this at the moment as I have switched to a more appropriate diagram for my purposes, however thank you for pointing me in this direction.:-)
