Author Topic: Don't want elements to be embedded in diagrams  (Read 2498 times)
Dalia
« on: October 16, 2014, 04:47:25 am »
I constructing a diagram and I'm nesting or embeding multiple elements.
When draging an object outside of another one, the element hierarchy is changed on the project browser but when dragging it inside (embed) it doesn't affect the hierarchy int he product browser.
The option "Support for composite objects" in Tools | Options | Objects is not selected.
It there a way to change the configuration so that when dragging inside and outside the hierarchy in the project browser is not affected?
Many thanks.
Dália
PS - I found the description below in the the file.
"When you embed a child element on its parent, the child element becomes part of the parent element hierarchy in the Project Browser. Similarly, if you drag the child element out of the parent, the child element becomes independent and is no longer embedded in the parent element hierarchy."
Re: Don't want elements to be embedded in diagrams
« Reply #1 on: October 16, 2014, 05:28:06 am »
I'd regard this a bug since the option clearly tells that the drag should have no influence. You should send a report (link bottom right of this page).
