Author Topic: entry function not visible in generated c++ code  (Read 3249 times)
vikrant
« on: October 30, 2014, 08:18:20 pm »
I could generate c++ code from state machine, but entry/exit/do functions entered in state machine are not appearing in auto generated c++ code.  Any special setting  required to get enty/exit functions in c++ code ? I am using 11.0.1107 version
Thanks and Regards,
Vikrant
MMA
Re: entry function not visible in generated c++ co
« Reply #1 on: November 06, 2014, 12:10:01 pm »
Hi vikrant,
The entry/do/exit code can be set at "State" element.
Double click on the operations you created in the state | Behavior tab | input "behavior code;" in the Behavior field, "initial code;" in the Initial Code field. The generated result will looks like below:
Note: you can update the template by using "behavior" field or "initial" field. Tools | Source Code Generation Templates | STM_C++_Structured | Stm State Proc Impl | search "$entry_behavior = " and "$entry_code = " | then togging "//" in the strings
bool MyClass::StateMachine_State1_behavior(StateBehaviorEnum behavior)
      switch (behavior) {
            case ENTRY:
                  StringStream ss;
                  ss << m_sInstanceName << "[" << m_sType << "]." << "StateMachine_State1 " << "ENTRY" << endl;
                  GlobalFuncs::trace(ss.str());
                  //behavior code;
                  initial code;
                  break;
            case DO:
                  StringStream ss;
                  ss << m_sInstanceName << "[" << m_sType << "]." << "StateMachine_State1 " << "DO" << endl;
                  break;
            case EXIT:
                  StringStream ss;
                  ss << m_sInstanceName << "[" << m_sType << "]." << "StateMachine_State1 " << "EXIT" << endl;
                  break;
      return true;
