Author Topic: Activity Diagram  (Read 7110 times)
ayman
Activity Diagram
« on: November 07, 2014, 02:44:23 am »
Sparx version 11:
according to help description for Structured Node "To display the Activity diagram represented by a Structured Activity Node element, double-click on the element"
Help URL: http://www.sparxsystems.com/enterprise_architect_user_guide/9.2/standard_uml_models/subactivity.html
but while trying to implement double click open the properties of structured node !!!!
so how can we do that?
« Last Edit: November 07, 2014, 02:52:24 am by ayman.yassin »
Helmut Ortmann
Re: Activity Diagram
« Reply #1 on: November 07, 2014, 06:12:30 am »
1. Click on the structured activity
2. ALT+G (goto element in browser)
3. Here you find the nested diagrams to open
Helmut
ayman
« Reply #2 on: November 07, 2014, 06:57:22 am »
it's not the issue if you have checked the mentioned URL you will figure out that the structured node contains composite icon, so how we can do that?
« Reply #3 on: November 07, 2014, 07:48:26 am »
Depends on the version. I'm on V11 now, but on 9.2 it should have been somewhere under Advanced/Make Composite. It will then either take the top most diagram in the element and assign that to be the composite one. Or it will create a new one. If you wanted to change it you needed to remove composition the same way, place the alternate diagram on top and redo composition.
« Last Edit: November 07, 2014, 07:48:44 am by qwerty »
ayman
« Reply #4 on: November 07, 2014, 07:55:10 am »
me too in V 11
yes u are right it is exist in the old versions
but is that an update in 11 ?
« Reply #5 on: November 07, 2014, 09:36:42 am »
You referred to 9.2 above in the link, so I thought you're on that version. Well, the function has changed. It's now found under New Child Diagram/Composite. Also you can select an arbitrary composite diagram for an element right there. IIRC it had changed from 9.3 to 10.
ayman
« Reply #6 on: November 07, 2014, 11:37:59 pm »
no i'm on version 11 but what makes the confusion is the online help as it seems it's for old version 9.2
but this means that structure activity node is not a composite element anymore with Version 11?
« Reply #7 on: November 08, 2014, 01:34:19 am »
A structured activity is just a normal one that is made composite. The toolbox offers a shortcut but you can always convert both into each other.
Regarding the help you should in general refer to the local help which is always up to date. The online help is okay for those which want to learn about EA without having purchased it. Honestly I don't know exactly which policy Sparx follows with the online help, so that was just a good guess.
ayman
« Reply #8 on: November 08, 2014, 02:37:20 am »
according to v 11 you can't convert Structured Activity Node to Composite one.
there is no child diagram option in the proprieties window or any other option.
BTW if u tried the local help u will find the same information as online one  :) it seems they didn't update the help!!!!
« Reply #9 on: November 08, 2014, 03:13:40 am »
Oh. I had just looked on the image in the help which is what I explained above. But actually the structured activity from the toolbox is a different element (e.g. the LoopNode show a stereotype additionally). I'll have a closer look later.
P.S. Those elements are ConditionalNode, Activity and LoopNode. I haven't verified this but likely you can create them via AddNew(name, <oneofthem>)
« Last Edit: November 08, 2014, 09:21:08 am by qwerty »
RoyC
  • Read The Help!
« Reply #10 on: November 10, 2014, 11:18:11 am »
The Help isn't quite accurate. I'm looking into it.
Best Regards, Roy
« Reply #11 on: November 10, 2014, 11:40:07 am »
A StructuredActivityNode is not a kind of Activity, it's a kind of Action. Actions can't have composite diagrams in EA (since EA 9.2.921) because they are atomic. Ditto, LoopNode and ConditionalNode are also kinds of Action. If you want to make a StructuredActivityNode composite, then I suspect that what you really want is a composite Activity.
« Last Edit: November 10, 2014, 11:55:46 am by KP »
RoyC
  • Read The Help!
« Reply #12 on: November 11, 2014, 12:15:52 pm »
I have updated the Help - changes will be visible at the next major release of EA. Basically, don't think of a Conditional Node, Loop Node, Sequential Node or Structured Node as a composite element with a child diagram - they aren't.
A SEQUENTIAL NODE element currently is flagged as a Composite element, but if you start to work with it as a Composite, it automatically transforms into a simple composite Activity element.
Best Regards, Roy
