Author Topic: Update() issues in Automation Interface  (Read 10776 times)
Alin Dobre
« on: July 22, 2009, 09:31:51 am »
Hello Everyone,
Have any of you run into a problem where every so often when updating an element the notes field gets completey erased and you lose everything. It seems to have started since I downloaded build 846, but Im not sure. Im going to keep testing to see if its something on my end, just thought I would post the question.
Thanks in Advance.
Alin Dobre
kosh.iii
Re: Update() issues in Automation Interface
« Reply #1 on: August 17, 2009, 07:56:20 pm »
I have a probably similar problem when updating a lot of infornation on diagrams or add tons of diagram links for a connector. Sometimes the memory consumption will just skyrocket and a few seconds after that a .GetConnectorByGuid or .GetConnectorByGuid will not find the desired object any more.
Have you checked if you really only loose the notes field?
« Reply #2 on: August 17, 2009, 09:45:32 pm »
Have you ensured that you have called Update on all new connectors? And have you called Refresh on all the collections to which the connectors have been added?
Until a parent collection has had Refresh called EA cannot 'see' new member items. Whether this extends to the repository as a whole (this covering retrieval by GUID) I cannot say.
almacivor
« Reply #3 on: August 18, 2009, 06:20:24 pm »
I'm having a similar issue.
I'm creating a new connector, and I call update, and then refresh the collections as follows:
con.SetClientID(srcEl.GetElementID());
con.SetSupplierID(tgtEl.GetElementID());
con.Update();
srcEl.GetConnectors().Refresh();
tgtEl.GetConnectors().Refresh();
However, I still get a null pointer when I call getConnectorbyGUID later!
« Reply #4 on: August 19, 2009, 12:53:17 am »
Perhaps you need to reload the project. There is a method to do that. I think it belongs to the Project class, but it could be Repository instead.
almacivor
« Reply #5 on: August 19, 2009, 10:15:19 pm »
gave that a go but it didn't seem to get me anywhere.
Interestingly, the connections it's being funny with are compositions - which EA seems to insist upon drawing the wrong way round...
« Reply #6 on: August 19, 2009, 11:14:48 pm »
There is an option somewhere to change the direction EA draws compositions.
« Reply #7 on: August 20, 2009, 09:05:23 am »
...somewhere...
When the Links page of the Tools | Options dialog was added this option migrated there. I still have trouble remembering where it has moved. [But it's only been about two years...]
almacivor
« Reply #8 on: August 20, 2009, 07:21:57 pm »
excellent.
thats been irritating me for about 2 years now.
« Reply #9 on: August 21, 2009, 11:20:25 am »
EA Compositions are (certainly used to be) internally self inconsistent.  You can find postings by me on the subject dating 5-6 years back.
Since EA itself in reverse engineering DOESN'T use EA Compositions I took the hint and have avoided their use completely.  We use normal Asscoaitions with the aggregation set appropriately.
This seems another reason for that avoidance...
« Reply #10 on: August 21, 2009, 12:08:16 pm »
Yes!
What Paolo says!
All of it!
The man knows of what he speaks.
