Author Topic: Traceability between Use Cases and Classes  (Read 3689 times)
Hardy
« on: November 12, 2014, 06:26:24 am »
I have requirement diagram (with requirements), use case diagram (with use cases), class diagram (with classes) in my model.
In my use case diagram I draw the realization relationship between use cases and requirements to illustrate how requirements are realized.
Then I begin to create sequence diagram as child diagram for each use case. In my sequence diagram I use instance of class as lifeline.
Now the question is that is there a way in traceability matrix I can find out the relationships between my classes and use cases and/or requirements?
« Last Edit: November 12, 2014, 06:27:19 am by hardywang »
Re: Traceability between Use Cases and Classes
« Reply #1 on: November 12, 2014, 06:30:07 am »
As the matrix is only two-dimensional the answer is clear: you can't. But you may use the traceability window for your purpose. It's also possible to create a query to reveal a more-dimensional relation.
