Author Topic: Relationship Matrix  (Read 5437 times)
RedEric
Relationship Matrix
« on: November 17, 2014, 08:46:14 pm »
I have imported via DOORS a set of requirements and was wondering if it is possible to create a link between the Requirements and Sequence Diagrams using the Relationship Matrix.
OpenIT Solutions
Re: Relationship Matrix
« Reply #1 on: November 17, 2014, 09:17:24 pm »
I don't think you can form a relationship between a diagram and an element (ie a requirement) via the relationship matrix (or any other means).
You would have to create an element then add the sequence diagram to it as a child (composite) diagram. Then relate your requirement to this element.
Jon.
« Reply #2 on: November 17, 2014, 11:14:53 pm »
How can requirements appear in SDs??
jfzouain
« Reply #3 on: November 18, 2014, 05:43:56 am »
If you drop the requirement imported (elements) to the Class (element-objects) inside the Sequence Diagram, you can see the link of the requirement inside the Class, go to Rules, Requirements.
Now you can create your Matrix, betwen those 2 packages (Requirement and Sequence).
You can only create the Matrix betweel elements of different Diagram, not the Diagram itself.
Best regards
Jose Zouain
« Reply #4 on: November 18, 2014, 08:06:18 am »
Does not work for me (V11). When I drag a requirement onto a SD I always get a lifeline. Either as instance or as object. Both does not make any sense,
jfzouain
« Reply #5 on: November 18, 2014, 08:30:40 am »
After you create a Sequence Diagram by dragging classes to the Sequence Diagram as instance (creating your lifeline), then you drag your requirements to the Object Class, works for me in version 11.
Best regards
Jose Zouain
« Reply #6 on: November 18, 2014, 12:05:57 pm »
I see what you mean. But those "Internal Requirements" are actually responsibilities. Also you can not "see" them directly and they are not linked with a connector. I don't know why EA creates a responsibility with such a drag operation. There might be a reason. But finally I can't see how a requirement would appear in a SD in any way (to come back to the OP). A requirement can't lead to a design decision A must communicate with B because of this. No customer would ask "code a FOR loop and not a WHILE".
jfzouain
« Reply #7 on: November 19, 2014, 01:58:05 am »
That is how you create the Relationship Matrix in EA, you drag it in top of the element, this is how is done when you want to create a  Relationship Matrix between Requirements and Use Cases.
It works pretty nice.
Best regards
Jose Zouain
