Author Topic: Hide Stereotype conveyed object Information Flow  (Read 7312 times)
thomasbru
« on: November 19, 2014, 02:33:04 am »
The Common information flow allows to specify the Label Visibility (Visibility -> Set Label Visibility), so I can hide the <<flow>> label. Next I want to hide the stereotype of the conveyed objects because the type is always the same. How do I achieve that?
Thanks a lot and best regards,
 Thomas
Re: Hide Stereotype conveyed object Information Fl
« Reply #1 on: November 19, 2014, 09:58:32 am »
I believe you can only do this by hiding all stereotypes on a diagram: Diagram > Properties > Elements > Show Element Stereotypes
thomasbru
« Reply #2 on: November 21, 2014, 01:09:47 am »
Thanks for your help KP unfortunately this setting does not effect the conveyed ArchiMate Data Objects.
« Reply #3 on: November 21, 2014, 01:50:31 am »
I assume those are created with a shape script and do not honor those settings.
« Reply #4 on: November 24, 2014, 11:48:26 am »
I believe this means your EA is earlier than 11.0.1105
