Author Topic: Call Trigger State Machine Diagram  (Read 3232 times)
philchudley
« on: November 25, 2014, 03:47:54 am »
Hi All
I have noticed the following in SysML 1.3 EA version 11.1, but I am assume the same "behaviour" is also true for UML
In a State Machine diagram that is a child of a Block (or Class), and that Block has operations defined in it, a Call Trigger can be set in EA and quite correctly you can pick the operation pertaining to the trigger.
BUT, nothing shows on the diagram!!
You are forced to name the Trigger, (space will do), but rather than displaying the Operation name that is being called by the trigger, EA displays the trigger name.
Is this a bug?
If not it rather defeats the object of linking a Call trigger to an operation
Yes I can name the Trigger to be that of the operation, but that's not ideal
Am I missing something?
Models are great!
