Author Topic: Create Customized EA UI Screen Element  (Read 3813 times)
tobinho
« on: August 25, 2009, 10:53:38 pm »
Hi all,
i would like to create a customized EA UI Screen Element (UI Control).
If i select the stereotype "checkbox" for it, a little checkbox is in the right upper corner of the UI Control Element. How can i change this symbol for another "stereotype" ???
I tried it with the image manager and Settings/UML... - Stereotype, but only the hole image is there. How can i make settings, that the image is only in the right upper corner ???
Thx a lot.
UPDATE:
I found following topic: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1245909984/1#1
With the shape script editor i could insert a customized image - ok.
BUT - How can i fading out the stereotype ???
If i define a stereotype: name x class: guielement shape-script: no
The stereotype is fading out.
If i define a stereotype: name y class: guielement shape-script: yes
The stereotypename is shown in the element  :-/
« Last Edit: August 26, 2009, 12:37:00 am by tobinho »
