Author Topic: CSV Export  (Read 4924 times)
Jayson
CSV Export
« on: November 25, 2014, 03:54:06 am »
I have been using the CSV exporter, which is all very simple and behaves nicely except that it doesn't seem to work with tagged values.
Has anyone else struck this problem or have a solution to it?
Cheers
Jays  :)
Aaron B
Re: CSV Export
« Reply #1 on: November 25, 2014, 10:06:08 am »
Can you please confirm which program version of Enterprise Architect you are currently running?  (See: Help | About EA)
Have you tried adding a TagValue_ or TagNotes_ column to your CSV import/export specification by clicking the "Add Tagged Value Field" button?
http://www.sparxsystems.com/enterprise_architect_user_guide/11/projects_and_teams/csvspecifications.html
What type of tagged value you are trying to export?  What is the result in your CSV?
« Last Edit: November 25, 2014, 10:06:34 am by AaronB »
Jayson
Re: CSV Export
« Reply #2 on: November 25, 2014, 10:42:37 am »
Hi, I'm running 9.3.
I have gone in and added both tagged value field -> value and -> notes.
When the file opens, the fields are blank.
Cheers  :)
Jayson
Re: CSV Export
« Reply #3 on: November 25, 2014, 10:43:52 am »
Oops!
Forgot to mention they are my own tagged values and are a mix of RefGUID, int, string ,etc.
Donster
Re: CSV Export
« Reply #4 on: November 28, 2014, 03:22:26 am »
As far as I know, exporting Tagged values is not available via CSV exporter in version 9... I think it was added in 10.
I am running v9.0.908, so I'm not sure if the "Add Tagged Value Fields" is available in the CSV Import/Export Specification window... it's not in v 9.0.908
I hope that helps!
Don
Jayson
Re: CSV Export
« Reply #5 on: November 28, 2014, 03:33:04 am »
Cheers Don!
Looks like its time to switch to 11 then!
We have both 9.3 & 11 running, but I have been timid to migrate in case my MDGs break.
