Author Topic: Neaten report output by adding bookmarks  (Read 3462 times)
stevesavage
« on: December 05, 2014, 05:08:21 am »
On: http://www.sparxsystems.com/products/ea/11/beta/index.html#reporting
There is:
  • Define a Template Fragment that calls a different fragment based on element type
  • Neaten report output by adding bookmarks to support conditional output
  • Define a header to be generated for the first item only
  • Define a list separator to be generated for items other than the first
  • Conditionally write text around any field only if it is non-empty
  • See system reports for examples
For the last line "See system reports for examples" could you be a bit more specific?  The only way for me to see bookmarks in these examples is to copy the template documents  one at at a time to see if it "might" be the one you are talking about (can't view bookmarks on the originals)
I have this working for:
  • {Element.Notes.Start} {Element.Notes} {Element.Notes.End}, and
  • {Element.valueOf(aTaggedValue).Start} {Element.valueOf(aTaggedValue)} {Element.valueOf(aTaggedValue).End}
I haven't figured out how to do this for custom fields yet.
I did find the info on:
custom>{CustomSQL_TITLE_Begin}Label: {CustomSQL_TITLE_End}{CustomSQL_LIST_Begin}, {CustomSQL_LIST_End}{FieldName}<custom
I'd like to change my output depending on {FieldName} being null or providing a value.
{CustomSQL.FieldName.Start} {FieldName} {CustomSQL.FieldName.End} does not seem to work.
Re: Neaten report output by adding bookmarks
« Reply #1 on: December 08, 2014, 09:16:08 am »
I don't think it works for custom fields. It may have been done for v12, but I'm not 100% sure.
