Author Topic: How to make property type visible.  (Read 3925 times)
ngong
« on: December 08, 2014, 06:20:55 am »
SysML: I placed a property in an internal block diagram by dragging a block in that diagram expecting to see some text like /PropertyType inside that block. But it did not appear.  :-[
Probably I am too blind to find the regarding checkbox. Can someone help me here and point me to a solution? :)
I am using EA11.1112.
Rolf
p.s. in the Sparx example I found some properties which show their type but cannot tell the difference to properties which hide their type.
« Last Edit: December 08, 2014, 06:37:08 am by ngong »
Rolf
philchudley
Re: How to make property type visible.
« Reply #1 on: December 08, 2014, 08:52:32 am »
[highlight]Use the Tools -> Options..  menu
Select Objects
Check the checkbox "Port and Part type visible by default"
[/highlight]
That should solve the problem
Cheers
Phil
Models are great!
ngong
« Reply #2 on: December 08, 2014, 09:31:50 am »
Works, thank you Phil.
Rolf
