Author Topic: Reporting a single tag value  (Read 4507 times)
Jeff Odell
« on: November 27, 2014, 09:56:52 am »
You can report the set of tags associated with an element in the report templating engine using:
tagged value >
{FeatTagVal.Name} = {FeatTagVal.Value}
<tagged value
Is there a way to print an individual tag value rather than the entire list?
Re: Reporting a single tag value
« Reply #1 on: December 01, 2014, 08:50:26 am »
Right click in the element section
Select Insert Field | valueOf
Type the name of the tag that you want to report.
You end up with something like:
{Element.valueOf(assignedTo)}
Jeff Odell
« Reply #2 on: December 11, 2014, 05:38:44 am »
This does not seem to work with attributes ... I'm trying to get either the 'property' tag or the 'AutoNum', 'StartNum' and 'Increment' values from a column in a table.
The default table template has:
tagged value>
 Properties:
    {FeatTagVal.Name} = FetaTagVal.Value}
< tagged value
I removed this tag so I was within the <attribute tag.  The valueOf field is offered, but when I put it in I get:
{Att.valueOf(property)}
and it does not print
Am I missing something?  Thanks for your reply.
