Author Topic: HELP! - BPMN connectors dancing allover ! ?  (Read 8208 times)
Svend Erik Nygaard
  • Business Information Architect
« on: December 18, 2014, 04:09:13 am »
HELP :-/ :-)
When we create BPMN diagrams, we spend a lot of our time desperately trying to make e.g. the sequence flows position as we want - but they are dancing all over.
I'm sure we are missing some point here - what is the trick to make the connectors fall into the lines where we them?
(Currently on EA 10 - will be on EA 11 by January)
« Last Edit: December 18, 2014, 04:12:36 am by svenderiknygaard »
ducatiross
Re: HELP! - BPMN connectors dancing allover ! ?
« Reply #1 on: December 18, 2014, 04:53:18 am »
Have you got the options set so that the New Connector End Points are Center-to-Center ?
Use Tools>Options>Links and it is on the right of the dialog box.
Certain lines go a bit weird though, especially from Gateways to Activities - in this case, ensure the Line Style is Direct (or Orthoganol) depending on how you place your elements on the diagram.
« Reply #2 on: December 18, 2014, 08:50:33 am »
The behavior you're describing sounds like issues that we used to have with orthogonal connector styles. It has improved since v10.
sgolemon
« Reply #3 on: December 18, 2014, 09:46:57 am »
I've had similar issues (Currently on EA 11).  I've tried various settings in the Tools>Options>Links and it's currently set to Direct line style but still the issue persists.  I see it mainly between vertical Events and Gateways....the sequence flow connects out of alignment when the objects are lined up.
OpenIT Solutions
« Reply #4 on: December 18, 2014, 07:44:19 pm »
FYI - we are still seeing the same behavior in v11 and v12 beta. The issue pops up if you use orthogonal connectors - but take the time to lay them out - when you move any connected object - even just a fraction - sparx will try to reroute - and mess up your alignment. It is the top complaint of my modelers.
I guess there is still a change to resolve before v12 release ???!!??? I live in hope !
Svend Erik Nygaard
« Reply #5 on: December 18, 2014, 09:35:08 pm »
Thanks for your input (and support  8-))
I have tried all of the above suggestions.
And yes it is worst around gateways - very often it Sticks to the corner opposite of the desired one!!!
It is certainly the top complaint in my organization.
« Last Edit: December 18, 2014, 09:37:39 pm by svenderiknygaard »
ducatiross
« Reply #6 on: December 18, 2014, 09:43:08 pm »
Me too ! This issue exists for me in V11 and consumes a lot of time getting the lines to route properly.
Guillaume
    • www.umlchannel.com
« Reply #7 on: December 24, 2014, 06:41:39 pm »
Has anyone tried with the latest build 1113 to see if it's resolved the issue?
Build 1113 main enhancement: Many updates, conformance improvements and diagramming improvements originally included with version 12
Guillaume
