Author Topic: Model Views: How to export/import slideshows  (Read 3063 times)
thomas.w
« on: January 09, 2015, 07:31:00 pm »
Is there a way to transfer a slideshow via export/import from one model to another?
Using the export function creates an XML which only contains the views folders, but not the contents
Re: Model Views: How to export/import slideshows
« Reply #1 on: January 09, 2015, 08:34:45 pm »
It should be then in Export Reference Data. If not you need to send a feature request.
thomas.w
« Reply #2 on: January 09, 2015, 09:14:02 pm »
I could not spot something like model views in the export reference data selection dialog; selecting all upon export reference data and importing did not transfer slide shows to the new model.
Apparently it is a missing feature
« Reply #3 on: January 12, 2015, 08:45:37 am »
The problem is that reference data is the data independent of any packages/contents. Slideshows and favourites model views are dependent on the elements that appear in the current model.
