Author Topic: Find elements with no associations  (Read 2586 times)
MrBump
« on: January 13, 2015, 03:13:45 am »
Hi
I am trying to find a way to to get a list of elements (in this case classes) in the model that are not linked (have no associations) to any other elements.  There are a number of diagrams with classes on that still need associations adding to their "parent" but I don't know an easy way to find them all.
Any ideas?
Paul
Re: Find elements with no associations
« Reply #1 on: January 13, 2015, 06:27:51 am »
You can create a search like this:
SELECT ea_guid AS CLASSGUID, name FROM t_object
WHERE t_object.Object_ID NOT IN (SELECT  t_connector.Start_Object_ID FROM t_connector)
AND t_object.Object_ID NOT IN (SELECT  t_connector.End_Object_ID FROM t_connector)
I don't know if this is "sub-optimal" as I'm no SQL guru, but it will do the job.
« Last Edit: January 13, 2015, 06:28:20 am by qwerty »
