Author Topic: Disable Default Line Styles  (Read 5492 times)
minna
« on: January 28, 2015, 10:21:12 pm »
I am using a Activity Diagram. When I add connectors between Activities, the line style is LV (lateral Vertical) by default. I then change them to Custom (C) in order move them around to fit appropriately within my page.
The problem is that when I add a new connector, all the connectors change to LV again and I need to change all of then back to C and reposition them.
Is there any way to disable the default line style, so that when I add a new connector my current connectors will not change?
Minna
Re: Disable Default Line Styles
« Reply #1 on: January 29, 2015, 12:40:58 am »
Minna,
I'm not sure why, but adding a new connector should never ever change the style of the existing connectors on a diagram.
Do you have some kind of addin or script running?
minna
« Reply #2 on: January 29, 2015, 05:28:59 pm »
Hi Geert,
I don't think I have a script or addin running. But if I do, how do I check?
If nothing is running, then my only conclusion is that an Activity Diagram has a default line style.
Minna
« Reply #3 on: January 29, 2015, 06:18:43 pm »
Minna,
You better report this to support. AFAIK there is not way this can be considered normal behavior.
minna
« Reply #4 on: January 29, 2015, 06:29:06 pm »
Thanks Geert.
Is there any way to check if a script or addinn is running in Sparx EA?
Thanks!
minna
« Reply #5 on: January 29, 2015, 06:37:13 pm »
Hi Geert,
You were right. I found the addin that caused the problem.
Thanks for your help!
Minna
