Author Topic: (solved) Extend table metaclass  (Read 4719 times)
SCAIAndre
« on: February 09, 2015, 09:36:55 pm »
I want to create my own specific MTG for a DWH environment, having stereotypes for dimensions, facts, source and so on.
Creating an MTG as such works. I have my own stereotypes in a toolbox and can add them to diagrams.
But extending the table metaclass does seem to break some things.
While it is still possible to assign a database to an instance of my dimension stereotype, which extends UML::table in the MTG, I cannot set a data type (like NUMBER or varchar2) for the columns I add to the dimension instance.
If I cannot set a data type for a column on a table, I cannot define foreign keys on it.
Also, under tagged values of the dimension, I cannot set DBVERSION and OWNER. I can set a TABLESPACE, though.
See the source code for the MTG below.
Is it not possible, what I'm trying to do? Or am I doing something wrong?
TIA,
Andre
<MDG.Technology version="1.0">
  <Documentation id="DWHMODELSCAI" name="DWH Model Technology" version="1.0" notes="Reference Model to define the structure of a DWH" infoURI="http://www.scai.de/"/>
  <UMLProfiles>
    <UMLProfile profiletype="uml2">
      <Documentation id="CD5F51F6-3" name="DWH" version="1.0" notes="DWH"/>
      <Content>
        <Stereotypes>
          <Stereotype name="Dimension" metatype="Dimension" notes="" cx="139" cy="70" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
              <Apply type="Table">
                <Property name="_Tag" value="1"/>
                <Property name="_TagInh" value="1"/>
              </Apply>
            </AppliesTo>
          </Stereotype>
        </Stereotypes>
        <TaggedValueTypes/>
      </Content>
    </UMLProfile>
  </UMLProfiles>
  <TaggedValueTypes>
    <RefData version="1.0" exporter="EA.25">
      <DataSet name="Property Types" table="t_propertytypes" filter="Property='#Property#'"/>
    </RefData>
  </TaggedValueTypes>
  <DiagramProfile>
      <Documentation id="1B130986-F" name="DWH" version="1.0" alias="DWH" notes="DWH"/>
      <Content>
        <Stereotypes>
          <Stereotype name="dwhModel" notes="" cx="90" cy="70" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
              <Apply type="Diagram_Logical">
                <Property name="alias" value="DWHModel"/>
                <Property name="diagramID" value="dwhmodel"/>
                <Property name="toolbox" value="DWH"/>
              </Apply>
            </AppliesTo>
          </Stereotype>
        </Stereotypes>
        <TaggedValueTypes/>
      </Content>
    </UMLProfile>
  </DiagramProfile>
  <UIToolboxes>
      <Documentation id="CFEA2654-E" name="DWH" version="1.0" notes="DWH"/>
      <Content>
        <Stereotypes>
          <Stereotype name="DWH" notes="Contains DWH Elements" cx="278" cy="174" bgcolor="-1" fontcolor="-1" bordercolor="-1" borderwidth="-1" hideicon="0">
            <AppliesTo>
              <Apply type="ToolboxPage"/>
            </AppliesTo>
            <TaggedValues>
              <Tag name="DWH::Dimension(UML::Table)" type="" description="" unit="" values="" default=""/>
            </TaggedValues>
          </Stereotype>
        </Stereotypes>
        <TaggedValueTypes/>
      </Content>
    </UMLProfile>
  </UIToolboxes>
</MDG.Technology>
« Last Edit: February 10, 2015, 04:14:48 am by SCAIAndre »
SCAIAndre
Re: Extend table metaclass
« Reply #1 on: February 10, 2015, 04:14:11 am »
In EA 11.1 this seems to work now to a certain extent.
In EA 10 I can change the stereotype of an table attribute. This seems not to be possible anymore in EA 11.1.
But there are more things I do not understand here. But I will open up new questions for that.
