Author Topic: Unassign Resource from element  (Read 5019 times)
Sunshine
  • Its the results that count
« on: February 09, 2015, 11:43:52 am »
Thought I'd try out the Gantt view of a diagram and assign resources (people) to the elements. Trouble is I can't find a way to unassign a resource. Tried searching the help and scouring the menus but no luck. Any help would be most welcome.
Happy to help
Aaron B
Re: Unassign Resource from element
« Reply #1 on: February 09, 2015, 11:51:07 am »
I think it's currently only possible to delete an assigned resource via the Resource Allocation window.  Right-click in the Gantt view and you should see an option like "Show Element Resource Allocation Window".  From the Resource Allocation window you should be able to delete a resource currently assigned to the selected element.
Edit: The above instructions are for EA 12.  If using EA 11, the "Resource Allocation" window was previously called "Project Management", and is opened via Element | Project Management.
« Last Edit: February 09, 2015, 02:36:05 pm by AaronB »
Sunshine
« Reply #2 on: February 10, 2015, 06:49:19 am »
Yeah forgot to mention using V11. That worked thanks Aaron.
Happy to help
