Author Topic: EA 12 DDL Code Generation  (Read 5984 times)
AlTumes
  • Reality leaves a lot to the imagination
« on: February 14, 2015, 05:06:32 am »
DDL Code Generation does not seem to work for me under EA 12. No matter what settings I chose, I just get a blank file generated.
Any suggestions?
Re: EA 12 DDL Code Generation
« Reply #1 on: February 14, 2015, 07:19:15 am »
Does it work with V11?
AlTumes
« Reply #2 on: February 16, 2015, 01:17:36 am »
Yes - it did work with V11.
A
« Reply #3 on: February 16, 2015, 03:14:05 am »
In that case you should send a bug report (and go back to V11). Someone else already suspected that Sparx test department seems to lack a bit of quality (to be polite) in relation to another issue with V12. From what I've seen in the past I would concur with that statement.
RoyC
  • Read The Help!
« Reply #4 on: February 16, 2015, 08:43:28 am »
How are you doing this? There are two methods for generating DDL in EA12. Are you using Tools | Database Builder?
Best Regards, Roy
AlTumes
« Reply #5 on: February 16, 2015, 10:40:59 pm »
I've tried the 'old' route, i.e. right click on package -> Code Engineering -> Generate DDL, and the 'new' one, i.e. Database Builder -> Database Compare Tab -> Generate DDL. Same result in both cases.
I'm going to raise a bug report and go back to V11.
