Author Topic: How to merge or reference different .eap files?  (Read 2993 times)
Ivan Filippenko
« on: February 13, 2015, 09:56:39 am »
If I'm developing a file A.eap and I want to refer to model information in file B.eap, how do I do it?  Ideally, I'd like simply to reference the info in B.eap from A.eap, so that changes in B will be felt by A.  But I realize that's probably too much to hope for.  So at least, how can I bring the B.eap models into A.eap?
« Last Edit: February 18, 2015, 03:44:24 pm by IvanAero »
Re: How to merge or reference different .eap files
« Reply #1 on: February 13, 2015, 10:30:15 am »
Search the help for controlled packages. It streamlines the export/import operations a little bit.
Ivan Filippenko
« Reply #2 on: February 13, 2015, 10:44:52 am »
Thank you for the tip. I will look into Controlled Packages and see whether they address my needs.
Ivan Filippenko
« Reply #3 on: February 13, 2015, 11:17:54 am »
Yes, it seems so -- at least you've given something to go on. Thanks! I have to see if I can make it work ...  I appreciate your prompt reply! :)
Ivan Filippenko
« Reply #4 on: February 18, 2015, 05:57:53 am »
Yes, Simon, that did the trick and was very helpful. Thank you!
