Author Topic: Relationship Matrix and traceability  (Read 6035 times)
MichaelB123a
« on: February 26, 2015, 11:20:57 pm »
I'm using the Relationship Matrix to map requirements to components, test cases etc.
I've set up two tiers of requirements - we have a whole bunch of customer requirements from different customers and then a rationalized set of product requirements.
I've currently mapped product requirements to one or more customer requirements. The product requirements are also then mapped to test cases with a trace association.
The trouble I'm having is using the Relationship Matrix to see the indirect relationships between a customer requirement and a test case:
customer reqt <-> product reqt <-> test case
I presume this is down to the Relationship Matrix only supporting one-hop relationships? Is there any way of achieving this if I were to change the type of relationships? For example, if I made the customer reqt a specialization of the product reqt? (tried that, didn't work  :( )
Maybe it's not possible, just wanted to see if it might be. Any help would be very much appreciated.
Michael
Robert Sheridan
Re: Relationship Matrix and traceability
« Reply #1 on: February 27, 2015, 12:07:28 am »
You are correct, the relationship matrix is for direct relationship maintenance. An alternative in the GUI is to use the traceability view - it shows all the connections for a selected element, you can also create it on diagrams for an element at a time using 'Insert Related Elements'.  If you need to get the information in a report and the supplied functionality does not work for you then you may need to use a SQL query as the source for the output.
MichaelB123a
« Reply #2 on: February 27, 2015, 03:01:50 am »
Thanks very much for your reply, I'll figure out another way of doing this.
Graham_Moir
« Reply #3 on: February 27, 2015, 05:54:01 am »
Yes, the request to be able to report on traceability in this way without needing to craft your own SQL has been out there for a very long time.
