Author Topic: Can't change stereotype "Message" into "message"  (Read 3559 times)
jakson
« on: March 06, 2015, 05:08:30 am »
I create new Class-element on a diagram and type "message" in stereotype field. After pressing "OK" the stereotype filed changes its contens into "Message" (first letter from lower to upper case).
When I dropdown stereotype combobox I can see "Message" and "message" items.
How to set / change element stereotype into "message"?
Where can I find (and edit) stereotypes popup list?
Re: Can't change stereotype "Message" into
« Reply #1 on: March 06, 2015, 07:05:07 am »
I just found out that stereotypes in EA are case insensitive. That's how Sparx implemented it.
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1425305428
« Last Edit: March 06, 2015, 07:05:45 am by qwerty »
Re: Can't change stereotype "Message" into "messag
« Reply #2 on: March 06, 2015, 06:02:49 pm »
Go to
Project|Settings|UML Types... (v12)
Settings|UML Types (v11 and prior)
There you can find and edit all defined stereotypes.
Also make sure you only have the MDG extensions activated that you actually use. I know <<Message>> is a standard BPMN stereotype for instance.
