Author Topic: Adding existing DB to Database builder  (Read 5281 times)
« on: March 12, 2015, 01:57:48 pm »
How do I open with, or add to, existing (reverse engineered) database to the (new in v12) database builder?
« Last Edit: March 12, 2015, 01:58:10 pm by skiwi »
MMA
Re: Adding existing DB to Database builder
« Reply #1 on: March 12, 2015, 03:28:22 pm »
1. Create a package e.g. "MyDatabase" and set the stereotype to "Database".
2. Tagged Values window | Create following tags (3rd button from left) for "MyDatabase":
   tag "DBMS" with value like "SQL Server 2012"
   tag "DefaultOwner" with value like "dbo"
3. Move existing tables into the package
4. Tools | Database Builder
Hope that helps  ;)
« Last Edit: March 12, 2015, 03:29:10 pm by milesma »
Aaron B
« Reply #2 on: March 12, 2015, 03:45:19 pm »
..Or perhaps an easier way would be to create a new Data Model from a pattern using the Model Wizard dialog, then move your existing tables below the resulting package structure.
- Right-click on a Package in the Project Browser, select Add Model using Wizard.
- Select Database, then select the appropriate data model to create.
You should now have a package structure like:
<<DataModel>> Data Model - [Database Type]
    <<Database>> [Database Type]
        Tables
Move your existing tables below the "Tables" package in this structure.  They should now be accessible from the Database Builder.
MMA
« Reply #3 on: March 12, 2015, 03:53:51 pm »
Aaron's solution is definitely better.
« Reply #4 on: March 20, 2015, 09:25:03 am »
Thank you both.
Because I have a large repository of reverse-engineered (by EA) DB schema the approach I took was
  • stereotype the outermost containing folder as «DataModel»
  • stereotype the folders containing the table objects where needed as «Database» (sometimes we place different table types in different packages, e.g. reference data, and have packages for differing diagrams)
  • add tagged values "DBMS" and "DefaultOwner" to the «Database» stereotyped package
This avoided any moving or restructuring of the model.
