Author Topic: AppData\Roaming\Sparx Systems folder configuration  (Read 4310 times)
tortue
« on: March 26, 2015, 07:05:47 pm »
For security reasons (run EA in non administrator mode), I wish to moove the AppData\Roaming\Sparx Systems folder.
Is it possible to configure the folder to use for EA configuration files instead of AppData\Roaming\Sparx Systems folder ?
Thanks.
Re: AppData\Roaming\Sparx Systems folder configura
« Reply #1 on: March 26, 2015, 08:46:44 pm »
I don't think that's possible, but it shouldn't be necesarry.
A regular user should always have access to the %appdata% folder, that's what it is there for.
I guess you have a windows configuration issue if your user doesn't have access to his own %appdata% folder.
« Last Edit: March 26, 2015, 08:46:56 pm by Geert.Bellekens »
