Author Topic: State machine code generation doesn't work (Exampl  (Read 2543 times)
JohannK
« on: March 30, 2015, 06:32:06 pm »
When I open the example in "Learning Center -> Software Engineering -> Behavioral Code Generation" and execute "Code Engineering -> Generate Code" on the class DataProcessor I only get the code for the class but not for the state machine. I'm using EA11.
Do you know why EA doesn't generate the SM-code?
Thanks for your help!
JohannK
Here is the generated code:
//  DataProcessor.cs
//  Implementation of the Class DataProcessor
//  Generated by Enterprise Architect
//  Created on:      30-Mrz-2015 09:29:33
//  Original author: Chuck Wilson
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
public class DataProcessor {
      public class USBDevice {
            public USBDevice(){
            ~USBDevice(){
            public void CLEAR_FEATURE(){
            /// <param name="iNoOfBytes"></param>
            public string GET_CONFIGURATION(int iNoOfBytes){
                  return "";
            public string GET_DESCRIPTOR(int iNoOfBytes){
                  return "";
            public void GET_STATUS(){
            public void RESET(){
            /// <param name="dAddress"></param>
            public void SET_ADDRESS(double dAddress){
            /// <param name="uDescriptor"></param>
            public void SET_CONFIGURATION(long uDescriptor){
            public void SET_DESCRIPTOR(long uDescriptor){
            /// <param name="iFeatureNo"></param>
            public void SET_FEATURE(int iFeatureNo){
      }//end USBDevice
      /// <summary>
      /// end USBDevice
      /// </summary>
      private bool bDataRead;
      private bool bPoll;
      private bool bValid;
      private int iBytesReceived;
      private StreamWriter sw;
      public DataProcessor(){
      ~DataProcessor(){
      public void doReadSerialPort(){
      public void doReadUSB(){
      public void readNextByte(){
            //ReadNextByte
}//end DataProcessor
JohannK
Re: State machine code generation doesn't work (Ex
« Reply #1 on: March 30, 2015, 06:59:38 pm »
OK it seems that this feature is not supported in EA Corporate Edition.
