Author Topic: Find unrealized elements  (Read 5245 times)
Maggie
« on: April 01, 2015, 07:35:46 pm »
Hi
I have a package that contains a set of features that are realized by components in another package.
I can use the relationship matrix to show the realisations but what i want is something that tells me which features have not been realised.
Is there a way of showing this
Maggie
Re: Find unrealized elements
« Reply #1 on: April 01, 2015, 08:59:04 pm »
I remember having done that with a little script counting the number of realize relations and spitting out those which did not have any. Since I had my own document generator I got a nice document for that as well.
Going with the EA doc gen (which I simply don't use) you can probably write an SQL doing the same as above and use the found elements to create a report.
A simple search result would probably also serve well :)
Maggie
« Reply #2 on: April 01, 2015, 09:03:43 pm »
« Reply #3 on: April 02, 2015, 09:15:59 am »
This will get you started. It lists all Feature elements that aren't the source of a Realization. Just copy it into the SQL Scratch Pad and run it.
SELECT * FROM t_object WHERE Object_Type='Feature' AND Object_ID NOT IN
(SELECT DISTINCT Start_Object_ID FROM t_connector WHERE Connector_Type='Realisation')
Maggie
« Reply #4 on: April 02, 2015, 06:40:14 pm »
