Author Topic: A0 Printing  (Read 4280 times)
hgroenewold
A0 Printing
« on: April 09, 2015, 07:52:15 pm »
Hi there,
I was wondering if there is anyway to set-up A0 printing for files in EA12?
Harm
Modesto Vega
Re: A0 Printing
« Reply #1 on: April 09, 2015, 09:40:00 pm »
As long as you have an A0 capable "printer" install that should be fine. With "printer" I do not mean a physical printer, Microsoft XPS Document Writer or an Adobe PDF Writer would also do the trick.
If you have a A0 capable printer this what you need to do:
1) Either make if the default printer at OS level, if it is not, or go to File/Print Setup, change the printer there, choose the right paper size and chosen orientation.
Unfortunately, EA12 does not save a change to the later as part of of the project.
2) Go to page setup, choose A0 and the desired orientation
3) AFIK for each diagram you need to change the page setup, there are various ways of doing this.
Once you have changed the page setup for each diagram, EA12 saves the new paper settings and does not loose.
