Author Topic: Data import to EA  (Read 5210 times)
blabla
Data import to EA
« on: April 03, 2015, 01:29:55 am »
I'm using EA and UML at my first time.
Is there a possibilty to use a data series in EA in a State diagramm like in Stateflow (Matlab). And can I make settings about the simulation time like in Matlab (Simulink,Stateflow).
Thanks for any help  ;D
Dermot
Re: Data import to EA
« Reply #1 on: April 08, 2015, 02:10:09 pm »
UML Statechart simulation is supported, but not for graphical output. For a graphical output you might look at the SysML parametric simulation. There is a simulation example in the EAExample model:
 - Project Models.Systems Engineering.Requirements Model.Constraint Blocks.EchoDSP.EchoDSP
This gives a graphical sine wave output.
blabla
« Reply #2 on: April 09, 2015, 12:12:02 am »
Thank you for your good answer.
May be you know where I can type in the mathematical equations at the constraint Property properties like :Add
blabla
« Reply #3 on: April 10, 2015, 12:23:24 am »
Does sombody know how I can use the data import as an input signal?
Daten.xlsx is a artifact   (Excel)
