Author Topic: Search for generate code  (Read 5589 times)
razzo78
« on: April 09, 2015, 12:20:13 am »
i wanted to know if there is a fast way to find the classes for which I have not yet generated the source code.
Re: Search for generate code
« Reply #1 on: April 09, 2015, 10:06:26 am »
Try this search:
SELECT * FROM t_object WHERE Object_Type='Class' AND GenFile IS NULL
(GenFile stores the file name of the generated source file)
« Reply #2 on: April 09, 2015, 06:54:59 pm »
To make the above search ciickable modify it this way:
SELECT  ea_guid AS CLASSGUID, Object_Type AS CLASSTYPE, Name FROM t_object
« Last Edit: April 09, 2015, 06:55:35 pm by qwerty »
razzo78
« Reply #3 on: April 09, 2015, 11:24:37 pm »
Fantastic. Now if i want to have all'class method where Notes = NULL??
« Reply #4 on: April 10, 2015, 03:19:07 am »
Quite straight forward:
WHERE Object_Type='Class' AND t_object.Note  IS Null
razzo78
« Reply #5 on: April 10, 2015, 04:44:21 pm »
It's ok, but i need the methods of the class, no the class!
« Reply #6 on: April 10, 2015, 06:18:48 pm »
SELECT t_object.ea_guid AS CLASSGUID, t_object.Object_Type AS CLASSTYPE, t_object.Name, t_operation.Name as Op FROM t_object, t_operation
WHERE t_object.Object_Type='Class' AND t_operation.Notes  IS Null AND t_operation.Object_ID = t_object.Object_ID
You might also have a look into my Inside book which explains the above a bit.
